Install a Search Client in Salesforce Communities (Lightning)
In this article, you will learn how to replace the default Salesforce component, Search Results, with a SearchUnify package. The SearchUnify package runs as a native app and can fetch results from your org and external sources, such as your organization's YouTube channels, Slack discussions, and GitHub repositories right into your Community Cloud. The installation takes only a few minutes but goes a long way in enhancing user experience.
Comparison of Search Results Component and SearchUnify Package
When users are confronted with thousands of posts and articles, most choose to run a search. As a Salesforce admin, you can improve user experience by replacing the default Search Results component with a powerful SearchUnify package. This table summarizes the key differences between the both.
Search Results (Component) | SearchUnify Package | |
Default Component | Yes | No |
Native Support | Yes | Yes |
Global (Org) Search | No |
Yes |
Objects Supported | Articles, Discussions | Articles, Discussions, and all other standard and custom objects |
Results from External Sources | No | Yes |
Permissions Chart
Object | User Type | User can see |
Cases | Internal | All the cases in an org. |
Partner | All the cases that belong to the Partner's account. | |
Guest User | No cases are visible. | |
Customer |
All the cases that belong to the Customer's contacts. |
Articles | Internal | All the articles in Knowledge. |
Partner | All the Public articles and the articles visible to the Partner. | |
Guest User | All the Public articles. | |
Customer | All the Public articles and all the articles visible to the Customer. | |
Group Feed | Internal | All feeds of all the groups. |
External | All feeds of the groups of which the user is a member and all feeds from public groups. | |
All | All feeds of all the groups. | |
Guest | All feeds from public groups. | |
User Feed | Internal | All feeds of all the users. |
External | All feeds of all the users. |
Enable SearchUnify Search on Salesforce Communities
Create a Salesforce Lightning Search Client
- Ensure that Salesforce Communities are enabled. Skip this step if you already have a community.
- Create a Salesforce Lightning search client.
- Configure the Salesforce Lightning search client.
Install SearchUnify Package
- Visit Salesforce AppExchange, look up "searchunify", and open the top listing, SearchUnify - Cognitive Search & Insights for Salesforce.
- Click Get It Now.
- It's usually a good practice to install an app on Sandbox, instead of Production.
- Install the app for All Users. A warning might come up. Overlook it and proceed with installation.
The data flow between SearchUnify and your Salesforce org is managed through Remote Sites, of which two must be created before you can proceed with configuration. For instructions, check out Create Remote Sites in Salesforce.
Process SearchUnify Package
- Create a remote site using URL on the Search Configuration screen.
- Select Lightning from Choose Search Platform. A configurations page will appear. Enter the details and click Process.
- Select your community for configuration. Choose a Salesforce community where the search client will be installed.
- Enter Service Endpoint. It is your SearchUnify instance URL.
- Enter Provision Key. You can get it from your SearchUnify representative.
- Enter UID. It is your search client ID.
- Enter community page name. Select or create a page with full-width and only one column. The page name should be limited to lowercase letters and hyphens. Spaces are not allowed.
Add SearchUnify Instance to CSP Trusted Sites
- From Setup, go to Quick Find Box, find CSP Trusted Sites, and open it.
- Click New Trusted Site.
- In the form that opens, enter "SearchUnify" in Trusted Site Name and
{{instance URL}}
in Trusted Site URL. - Check all the CSP Directives and click Save.
Insert SearchUnify Search Component to a Community Page
- Open your community in the Builder mode. (From Setup, go to All Communities through Quick Find Box, and click Builder.)
- Move to Security from .
- Select Allow Inline Scripts and Script Access to Whitelisted Third-party Hosts from the Script Security Level dropdown.
- Click from the sidebar, select Theme, and enter Configure.
- Click , and from the Search Component drop-down select SUAuthBanner_1234 (where 1234 are the first four digits of your UID).
Don't See the Packages?
- Launch your Developer Console.
- In the window that pops up, click Open Lightning Resources from the File menu.
- Expand each resource to view its subfolders and activate the packages. Then, proceed to Configuration in step 6.
NOTE. In case you cannot find subfolders in a resource, delete the resource and create a Lightning Component of the same name and check again. To create a new Lightning Component, click New from File and then Lightning Component.
- Drag SUAuthSearch_1234 (where 1234 are the first four digits of your UID) to the Content section of the page you have selected or created.
You have successfully installed SearchUnify on Salesforce Communities.
