Install a Search Client in Salesforce Console
Find information right inside your console installed in Sales Cloud or Service Cloud. This article first gives an overview of how the Salesforce Console search client handles permissions and then walks you through the steps of installing and setting up a SearchUnify client in Salesforce Console. The installation consists of four (Classic) or five (Lightning) steps.
Permissions Chart
Object | User Type | User can see |
Cases | Internal | All the cases in an org. |
Partner | All the cases that belong to the Partner's account. | |
Guest User | No cases are visible. | |
Customer |
All the cases that belong to the Customer's contacts. |
Articles | Internal | All the articles in Knowledge. |
Partner | All the Public articles and the articles visible to the Partner. | |
Guest User | All the Public articles. | |
Customer | All the Public articles and all the articles visible to the Customer. | |
Group Feed | Internal | All feeds of all the groups. |
External | All feeds of the groups of which the user is a member and all feeds from public groups. | |
All | All feeds of all the groups. | |
Guest | All feeds from public groups. | |
User Feed | Internal | All feeds of all the users. |
External | All feeds of all the users. |
Installation Overview
Become a Knowledge User
- From in Salesforce, go to Quick Find Box, look up "Users", click Edit and check the Knowledge User box.
Enable Lightning Knowledge
Skip this step if you want to continue using Salesforce Classic to create and store articles.
- Find Knowledge Settings from Quick Find Box. Then check Yes, I understand the impact of enabling Salesforce Knowledge. and click Enable Lightning Knowledge.
Install a Client
- Visit Salesforce AppExchange, look up "searchunify", and open the top listing, SearchUnify - Cognitive Search & Insights for Salesforce.
- Click Get It Now.
- It's usually a good practice to install an app on Sandbox, instead of Production.
- Install the app for All Users. A warning might come up. Overlook it and proceed with installation.
Configure the Client
- Create a remote site using URL on the Search Configuration screen.
- Select Console from Choose Search Platform. A configurations page will appear. Enter the details and click Process.
- Select your application for Configuration. Choose either Sales Console or Service Console. The search client will be installed in the chosen console.
- Enter Service Endpoint. It is your SearchUnify instance URL.
- Enter Provision Key. You can get it from your SearchUnify representative.
- Enter UID. It is your search client ID.
- Enter jwt token expiration time(time should be in minutes). Enter any integer. The suggested value is 120.
Create a Custom Component
For Salesforce Lightning Users
- Click Setup from to open Quick Find Box.
- Launch App Manager.
- Select (or create) an app where the search client will be installed.
- Click Utility Items.
- Click Add Utility Item to launch a search box. Find and click Visualforce.
- Enter a name in Label. Ensure that the Panel Width is 500 and the Panel Height is 550.
- Select
SU Vf Console
from the Visualforce Page Name dropdown and click Save.
For Salesforce Classic Users
- Switch to Salesforce Classic.
- From Setup, go to Quick Find Box, and search for "custom console components."
- Add these values to the following fields:
- Name: yourCustomComponent
- Button Name: YOURBUTTON
- Width: 500
- Height: 550
- Component as VF page: SU_Vf_Console
- Check Fixed Height
- Click Save.
- From Quick Find Box, go to Apps and Edit. (Create a new Console app if you do not already have one.)
- Ensure that Cases are included in Choose Navigation Tab Items.
- Drag yourCustomComponent (step E) to Selected Components in Choose Console Components and Save.
- Launch yourCustomComponent from the app launch menu.
- Click on SearchUnify Knowledge Base to launch the search window.
- Start searching.
Activate Results Scrolling
- Copy the
<div>
snippet fromreadme
. - Log into your SearchUnify instance.
- Go to Search Clients > Edit > Designer.
- Paste the
<div>
in the CSS tab of Search Results Page and click Update.
Once the entire process is complete, you can open the app from App Launcher and start searching.
Find the App
To use the app, look up your component from App Launcher.
Usage
Upon installation, SearchUnify is added to the utility bar. Click it to launch the search client.
When the search client is launched, it presents results related to the case opened or active in the Primary Tab.When you switch between two Primary Tabs, the results page refreshes — so that the results are related to the active case. Navigation between subtabs doesn't refresh results.
Agents who run complex searches on a regular basis or need more information to scan simultaneously can switch to full-screen view by clicking .
To copy the link to a result, click . Clicking copies a hyperlinked result title in Salesforce Lightning. In Salesforce Classic, the copied data is from the field configured by the Admin. In Salesforce Lightning, the link contains the URL of the copied result, which can be pasted on a case page. In the next image, the second result "How Documents Are Ranked in SearchUnify" is copied from the search client and pasted on a case page.
To preview a result, support reps can click . Each preview counts as a conversion. The preview works on Salesforce articles and YouTube videos.
For those who have updated to Mamba '22, a feature to share articles and link them to cases as a comment has been introduced.
