Install a Search Client in Salesforce (Internal Users)
Find information faster right inside Salesforce (Sales Cloud, Service Cloud, and others) with SearchUnify. This article first explains how the search client for Internal users handles permissions and then takes you through the steps of installing and setting up a SearchUnify client in Salesforce.
Permissions Chart
Object | User Type | User can see |
Cases | Internal | All the cases in an org. |
Partner | All the cases that belong to the Partner's account. | |
Guest User | No cases are visible. | |
Customer |
All the cases that belong to the Customer's contacts. |
Articles | Internal | All the articles in Knowledge. |
Partner | All the Public articles and the articles visible to the Partner. | |
Guest User | All the Public articles. | |
Customer | All the Public articles and all the articles visible to the Customer. | |
Group Feed | Internal | All feeds of all the groups. |
External | All feeds of the groups of which the user is a member and all feeds from public groups. | |
All | All feeds of all the groups. | |
Guest | All feeds from public groups. | |
User Feed | Internal | All feeds of all the users. |
External | All feeds of all the users. |
Installation Overview
- Connection between the search client and at least one Salesforce content source
Install the Search Client
- Visit Salesforce AppExchange, look up "searchunify", and open the top listing, SearchUnify - Cognitive Search & Insights for Salesforce.
- Click Get It Now.
- It's usually a good practice to install an app on Sandbox, instead of Production.
- Install the app for All Users. A warning might come up. Overlook it and proceed with installation.
Configure Your Client
- Create a remote site using URL on the Search Configuration screen.
- Select Internal from Choose Search Platform. A configurations page will appear. Enter the details and click Process.
- Enter Service Endpoint. It is your SearchUnify instance URL.
- Enter Provision Key. You can get it from your SearchUnify representative.
- Enter UID. It is your search client ID.
- Enter jwt token expiration time(time should be in minutes). Enter any integer. The suggested value is 120.
- Spot this message to confirm a successful configuration.
- From the app launch menu, go to SearchUnify Vf Internal.
- Click SearchUnifyInternal to launch the search client.
- Start searching.
