Install a Search Client in Salesforce Communities (Visualforce)
This article shows how to set up the SearchUnify search in a Visualforce community. The installation takes only a few minutes but goes a long way in enhancing user experience.
Permissions Chart
Object | User Type | User can see |
Cases | Internal | All the cases in an org. |
Partner | All the cases that belong to the Partner's account. | |
Guest User | No cases are visible. | |
Customer |
All the cases that belong to the Customer's contacts. |
Articles | Internal | All the articles in Knowledge. |
Partner | All the Public articles and the articles visible to the Partner. | |
Guest User | All the Public articles. | |
Customer | All the Public articles and all the articles visible to the Customer. | |
Group Feed | Internal | All feeds of all the groups. |
External | All feeds of the groups of which the user is a member and all feeds from public groups. | |
All | All feeds of all the groups. | |
Guest | All feeds from public groups. | |
User Feed | Internal | All feeds of all the users. |
External | All feeds of all the users. |
Create a Salesforce Visualforce Search Client
- Ensure that Salesforce Communities are enabled. Skip this step if you already have a community.
- Create a Salesforce Visualforce search client.
- Configure the Salesforce Visualforce search client.
Install SearchUnify Package
- Visit Salesforce AppExchange, look up "searchunify", and open the top listing, SearchUnify - Cognitive Search & Insights for Salesforce.
- Click Get It Now.
- It's usually a good practice to install an app on Sandbox, instead of Production.
- Install the app for All Users. A warning might come up. Overlook it and proceed with installation.
The data flow between SearchUnify and your Salesforce org is managed through Remote Sites, of which two must be created before package processing. For instructions, check out Create Remote Sites in Salesforce.
Process SearchUnify Package
- Create a remote site using URL on the Search Configuration screen.
- Select Visualforce from Choose Search Platform. A configurations page will appear. Enter the details and click Process.
- Select your community for configuration. Choose a Salesforce community where the search client will be installed. In the image, the community chosen is "Aniruddha".
- Enter Service Endpoint. It is your SearchUnify instance URL. You can find it in the readme file.
- Enter Provision Key. Get it from your SearchUnify representative.
- Enter UID. It is the ID of the downloaded search client.
- Enter community page name (Optional). Select or create a page with full-width and only one column. The page name should be limited to lowercase letters and hyphens. Spaces are not allowed. In the image, the page name is "searchunifysearchpage".
- Enter Expiration Time. Write a number between 1 and 120.
You have configured the search successfully. means that SearchUnify has been installed on your VF community.
Add SearchUnify Instance to CSP Trusted Sites
- From Setup, go to Quick Find Box, find CSP Trusted Sites, and open it.
- Click New Trusted Site.
- In the form that opens, enter "SearchUnify" in Trusted Site Name and
{{instance URL}}
in Trusted Site URL. - Check all the CSP Directives and click Save.
Set up on Community Homepage
- If you are on Classic, then from Setup, go to Quick Find Box, look up "Sites" and open Sites in Build > Develop; as is shown in the next image. The path for Lightening users, from the search box, is User Interface > Sites and Domains > Sites.
- Scroll down to find your community and open it.
{{Home Page Name}}
against Active Site Home Page. In the image, the home page name is "CommunitiesLanding". - Click Edit.
- There are two ways to set up search on the community:
- Type I. Both the search box and search results are right on the home page. The illustration used in this article is Type I. To proceed with Type I, edit the existing code and insert
<su_vf_console:SU_Vf_Community_Component />
on the page. The final code looks as in the image. - Type II. The search box is on the home page but the results are displayed on a community page specifically created to host them. If you are going with Type II, then name the page in Enter community page name (Step 4 of Process SearchUnify Package). To proceed with Type II, edit the existing code and insert
<su_vf_console:SU_Vf_Community_Searchbox />
- Scroll down to Site Visualforce Pages and click Edit.
- Add
su_vf_console.SU_Vf_Community
to Enabled Visualforce Pages, and click Save. IMPORTANT. If you are not hosting the search box on the home page (Type 2 in step 5), then add the search page (Enter community page name in step 4 of Process SearchUnify Package) to Enabled Visualforce Pages as well. - From Sites (step 1), click the Site URL of your community to view SearchUnify search client on its home page.
The search results update when you click anywhere outside the search box, even when you are still typing.
