Python SDKs
The Python SDK can be used to fetch analytics data, render search results, and obtain information on content source data.
Prerequisite
Install python 3.0 or higher.
Initialization
Before using SDK you must have to initialize first. In this process you just need to ensure authentication. We have two methods to generate and refresh access tokens. After initializing SDK you can access SearchUnify analytics, content and search.
Initialize Python SDK
from searchunify import startClient, refreshToken
username = "**************"
password = "**************"
clientId = "**************"
secrets = "**************"
url= "yourcompany.searchunify.com"
result = startClient(username=username, password=password,clientId=clientId, secrets=secrets, instance=url)
The access token expires every four hours. You can refresh it with the refreshToken() function.
Generate refresh token
result = refreshToken()
Analytics
To access analytics data you can use analytics functions. There are around 22 methods for various use cases.
Returns data on visitors, search users, clicks, results, cases, and other essential search behavior.
Parameters
Parameter | Optional / Required | Type |
startDate | Required | String |
endDate | Required | String |
searchClientId | Optional | String |
Example Request
getTilesData()
from searchunify import *
startDate = "2021-05-25"
endDate = "2021-06-01"
searchClientId = "5815771e-69dc-11eb-94cc-0242ac120007"
data = getTilesData(startDate=startDate, endDate=endDate, searchClientId=searchClientId)
print("The tile data ", data)
Returns how All Searches, All Searches with Results, and All Searches with Clicks (conversions) have changed over the period between startDate and endDate.
Parameters
Example Request
getSearchSummaryChart()
data = getSearchSummaryChart(startDate=startDate, endDate=endDate, searchClientId=searchClientId)
print("The getSearchSummaryChart data ", data)
Returns the most popular search queries.
Parameters
count | Required | Integer |
Example Request
getAllSearchQuery
startDate = "2021-06-01"
endDate = "2021-06-04"
count = 5
result = getAllSearchQuery(startDate=startDate, endDate=endDate,count=count, searchClientId=searchClientId)
print("The getAllSearchQuery data ", result)
Returns the most popular search queries for which results were found.
Parameters
Example Request
searchQueryWithResult
count = 5
result = searchQueryWithResult(startDate=startDate, endDate=endDate,count=count, searchClientId=searchClientId)
print("The searchQueryWithResult data ", result)
Returns the most popular search queries for which results were found but users didn't click on any of them.
Parameters
Example Request
searchQueryWithNoClicks
count = 5
result = searchQueryWithNoClicks(startDate=startDate, endDate=endDate,count=count, searchClientId=searchClientId)
print("The searchQueryWithNoClicks data ", result)
Returns the most popular search queries for which no results were found.
Parameters
Example Request
searchQueryWithoutResults
count = 5
result = searchQueryWithoutResults(startDate=startDate, endDate=endDate,count=count, searchClientId=searchClientId)
print("The searchQueryWithoutResults data ", result)
Returns search and conversion data over the period between startDate and endDate.
Parameters
Example Request
searchQueryHistogram
count = 5
result = searchQueryHistogram(startDate=startDate, endDate=endDate,count=count, searchClientId=searchClientId)
print("The searchQueryHistogram data ", result)
Returns the total number of queries that didn't produce even one result.
Parameters
Example Request
missedQueryHistogram
count = 5
result = missedQueryHistogram(startDate=startDate, endDate=endDate,count=count, searchClientId=searchClientId)
print("The missedQueryHistogram data ", result)
Return the activity on a case.
Parameters
caseUID | Required | String |
Example Request
searchSessionByCaseUidAuth
count = 5
caseUID = "5815771e-69dc-11eb-94cc-0242ac120007"
result = searchSessionByCaseUidAuth(
startDate=startDate, endDate=endDate, count=count, caseUID=caseUID)
print("The searchSessionByCaseUidAuth data ", result)
Prints a list of the count most popular documents. For count=5, you will get 5 results. The data is from between startDate and endDate on a search client whose ID is searchClientID. If the searchClientID is not specified, then the call fetches data from all the search clients.
Parameters
Example Request
getAllSearchConversion
count = 1
result = getAllSearchConversion(startDate=startDate, endDate=endDate,count=count, searchClientId=searchClientId)
print("The getAllSearchConversion data ", result)
Prints a list of the count documents that are not on the first page. These documents can be boosted to enhance search experience.. For count=5, you will get 5 results. The data is from between startDate and endDate on a search client whose ID is searchClientID. If the searchClientID is not specified, then the call fetches data from all the search clients.
Parameters
Example Request
searchConversionNotOnFirstPage
count = 5
result = searchConversionNotOnFirstPage(startDate=startDate, endDate=endDate,count=count, searchClientId=searchClientId)
print("The searchConversionNotOnFirstPage data ", result)
Prints a chart of the popularity (indexData) of all your content sources (indexName). The data is presented in an alphabetical order and includes: objectName, objectData, filterName, filterData, facetName, and facetName. An objectName is a content type and a filter is a high-level facet. The data is from between startDate and endDate.
Parameters
Example Request
searchConversionWithFilters
result = searchConversionWithFilters(startDate=startDate, endDate=endDate)
print("The searchConversionWithFilters data ", result)
Prints a list of the count most popular searches in a session. For count=5, you will get 5 results. The data is from between startDate and endDate on a search client whose ID is searchClientID. If the searchClientID is not specified, then the call fetches data from all the search clients.
Parameters
sessionId | Required | String |
Example Request
searchConversionBySessionId
endDate = "2021-06-07"
count = 5
sessionId = "16227428473203630"
result = searchConversionBySessionId(
startDate=startDate, endDate=endDate, count=count, sessionId=sessionId, searchClientId=searchClientId)
print("The searchConversionBySessionId data ", result)
Prints count discussions that have been accessed the most and can be converted into articles. The data is from between startDate and endDate.
Parameters
internalUser | Optional | String |
Example Request
discussionsReadyToBecomeArticles
endDate = "2021-06-05"
count = 2
internalUser = "all"
result = discussionsReadyToBecomeArticles(startDate=startDate, endDate=endDate, count=count, internalUser=internalUser)
print("The discussionsReadyToBecomeArticles data ", result)
View the list of articles that were consulted before a user created a case.
Parameters
searchClientId | Required | String |
count | Optional | Integer |
searchType | Required | String |
offset | Optional | Integer |
Example Request
getCaseCreatedArticles
internalUser = "false"
searchType = "global"
offset = 0
count = 10
result = getCaseCreatedArticles(startDate=startDate, endDate=endDate, searchClientId=searchClientId, count=count, internalUser=internalUser, searchType=searchType, offset=offset)
print("The getCaseCreatedArticles data ", result)
Returns the articles that were consulted by users who didn't create a case.
Parameters
internalUser | Required | String |
Example Request
getCaseDeflectedArticles
offset = 0
count = 10
result = getCaseDeflectedArticles(startDate=startDate, endDate=endDate, searchClientId=searchClientId, count=count, internalUser=internalUser, searchType=searchType, offset=offset)
print("The getCaseDeflectedArticles data ", result)
Find out how many articles have been attached to cases.
Parameters
Example Request
getAttachedArticles
offset = 0
count = 10
result = getAttachedArticles(startDate=startDate, endDate=endDate, searchClientId=searchClientId, count=count, internalUser=internalUser, offset=offset)
print("The getAttachedArticles data ", result)
From the article URL, find out which cases it has been attached to.
Parameters
url | Required | String |
Example Request
getAttachedOnCase
url = "https://cases/salesforce/article/qwe/1"
offset = 0
count = 10
result = getAttachedOnCase(startDate=startDate, endDate=endDate, searchClientId=searchClientId, count=count, offset=offset, url=url)
print("The getAttachedOnCase data ", result)
Prints a list of the count search sessions and the searches conducted in each session. For count=5, you will get 5 results. The data is from between startDate and endDate on a search client whose ID is searchClientID. If the searchClientID is not specified, then the call fetches data from all the search clients.
Parameters
Example Request
getSearchQueryInSessions
count = 10
result = getSearchQueryInSessions(startDate=startDate, endDate=endDate, count=count, searchClientId=searchClientId)
print("The getSearchQueryInSessions data ", result)
Prints the number of articles generated on your cases between startDate and endDate on a search client whose ID is searchClientID. If the searchClientID is not specified, then the call fetches data from all the search clients.
Parameters
Example Request
getKcsSupportSearchQuery
count = 10
result = getKcsSupportSearchQuery(startDate=startDate, endDate=endDate,count=count, searchClientId=searchClientId)
print("The getKcsSupportSearchQuery data ", result)
Provides search, conversion, page views, case deflection, and case creation data for the argument caseUid.
Parameters
Example Request
getSearchSessionByCaseUid
caseUid = "5815771e-69dc-11eb-94cc-0242ac120007"
result = getSearchSessionByCaseUid(startDate=startDate, endDate=endDate, caseUid=caseUid, count=count)
print("The getSearchSessionByCaseUid data ", result)
Prints a list of the count queries in a search session and the documents accessed during that session. For count=5, you will get 5 results. The data is from between startDate and endDate on a search client whose ID is searchClientID. If the searchClientID is not specified, then the call fetches data from all the search clients.
Parameters
sessionId | Optional | String |
pageNumber | Optional | Integer |
Example Request
getSearchSessionBySearchSessionId
count = 10
sessionId = "16225418602588530"
pageNumber = 1
result = getSearchSessionBySearchSessionId(startDate=startDate, endDate=endDate, searchClientId=searchClientId, count=count, sessionId=sessionId)
print("The getSearchSessionBySearchSessionId data ", result)
Content
This includes the methods for content source APIs. If you want to use content APIs can directly use these functions.
This function returns all the added content sources.
getContentSources
result = getContentSources()
print("The content source list: ", result)
Returns the id, label, name, url, and size of a content source, where size is the number of documents stored in the content source.
Parameters
contentSourceId | Required | String |
Example Request
getContentSourceById
contentSourceId = "2"
result = getContentSourceById(contentSourceId=contentSourceId)
print("The content source data: ", result)
Lists all the objects and fields of a content source in an array. Each element in the array is an object. Each object has four properties: id, label, name, and fields.
The fields element is also an object with six properties: id, name, label, type, isFilterable, and isSearchable. The type property can be an int, a boolean, or a string. isFilterable is a boolean object. If it is true, then the field is used as a facet. isSearchable is also a boolean object. If it is true, then the data stored in the field can be found through search.
Parameters
Example Request
getObjectAndFields
result = getObjectAndFields(contentSourceId=contentSourceId)
print("The object and fields: ", result)
Returns all the documents in your content source in an array and the size of the array. Each element in the array is an object.
Parameters
objectId | Required | String |
startFrom | Optional | Integer |
size | Optional | Integer |
Example Request
getObjectSpecificData
objectId = "2"
startFrom = 4
size = 10
Result = getObjectSpecificData(
contentSourceId=contentSourceId, objectId=objectId, startFrom=startFrom, size=size)
print("The object specific data: ", result)
Return data for particular object id.
Parameters
documentId | Required | String |
Example Request
getObjectSpecificDataWithId
objectId = "2"
documentId = "34717756"
result = getObjectSpecificDataWithId(
contentSourceId=contentSourceId, objectId=objectId, documentId=documentId)
print("The object specific id data: ", result)
Update any content field or document property in your index. The changes are reflected in your index. This call does not alter data on your content source. For instance, you can update a document title in the index without changing it in the content source.
Parameters
data | Required | Dict |
Example Request
updateDoucmentById
data = {
"tag":
"Search clients",
"Customer Experience"
"view_href": "https://vimeo.com/ID_HERE",
"title": "SDK bulk upload"
result = updateDoucmentById(
contentSourceId=contentSourceId, objectId="2", documentId="ID_HERE", data=data)
print("The document updated: ", result)
Add one or more documents to your search index. bulkUpload can be used instead of crawling from the Admin Console when:
You have only a few documents to add and you don't want to recrawl a large content source
You want to insert new documents into the search index without first deleting it, which happens when an admin crawls from the Admin Console.
Parameters
data | Required | JSON |
Example Request
bulkUpload
data = [
"id": "1236",
"content": {
"title": "New Templates for Search Clients - Part 1",
"post_time": 1573197537000,
"view_href": "https://vimeo.com/0123456",
"channel_id": "1234567",
"user_id": "01234567890"
"id": "1237",
"content": {
"title": "New Templates for Search Clients - Part 2",
"post_time": 1573197537010,
"view_href": "https://vimeo.com/0123457",
"id": "1238",
"content": {
"title": "New Templates for Search Clients - Part 3",
"post_time": 1573197537210,
"view_href": "https://vimeo.com/0123458",
result = bulkUpload(contentSourceId=contentSourceId, objectId="2", data=data)
print("The content source bulk upload: ", result)
Search
SDK has a search API to make content searchable. You just need to pass parameters as per requirement.
View search results on a platform of your choice.
Parameters
Parameter | Optional / Required | Description | Data Type |
uid
Required | It is your search client ID. You can find it in Search Clients > UID (column). | string |
searchString
Required | It is the search query. | string |
email
Optional | This parameter is used establish the searcher's identity and tailor search results based on that identity. An admin email might fetch results different from a moderator email. | string |
orderBy
Optional | It has two values, asc and desc . If orderby=desc , then the order in which the results are presented is reversed. The last result will be ranked first, the penultimate result second, and so on. The default value of orderBy is asc . |
string |
sortby
Optional | It can have two values, _score or _post_time . When sortby=_score , then the documents with the highest score are presented first. When sortby=_post_time , then the lastest documents are on top. |
string |
exactPhrase
Optional | It treats all the words in the search query as one contiguous string. exactPhrase=salesforce console becomes "salesforce console". |
string |
withOneOrMore
Optional | When used, it inserts the Boolean operator OR between each pair of keywords. withOneOrMore=salesforce console becomes "salesforce OR console". |
string |
withoutTheWords
Optional | This parameter inserts the Boolean operator NOT before each keyword. withoutTheWords=salesforce console becomes "NOT salesforce NOT console" |
string |
from
Optional | It's an offset. If from="10" , then the call will ignore the top 10 results and fetch results starting from the document ranked 11. |
string |
resultsPerPage
Optional | If resultsPerPage=30 , then each search will produce 30 results on each page. |
string |
indexEnabled
Optional | The content sources tabs are hidden if indexEnabled is set to false . In the default state, indexEnabled=true . |
boolean |
aggregations
Optional | aggregations is used to refine your search with facets. For example: type: ${facet name}, filter: [ ${facet filter name1}, ${facet filter name2} ] . A common pattern for nested facets is [{type: ${facet name},children: [ childname: ${facet child name1}, level: ${facet level} ]}] |
object |
pagingAggregation
Optional | It is used if your goal is to display all your facets. {key: ${facet name},keyword: ${facet search keyword},offset: ${number of filters to shown}} |
object |
pageNo
Optional | Returns search results from the specified page number. If pageNo==5 , then the results from the fifth page will be returned. |
sid
Optional | Attaches session ID(s) to the returned data. | |
language
Optional | Returns results in the specified language. language=zh returns Chinese results. |
versionResults
Optional | Merge multiple versions of a doc into a result. | |
getAutoTunedResult
Optional | Returns auto tuned results. Works only if Auto Spell Corrector and Facet Interpretor are enabled in the instance. | |
getSimilarSearches
Optional | Returns results from the similar searches tab. Works only if Similar Searches is turned on in the instance. | |
mergeSources
Optional | Groups results by content sources. Works only if Customize Search Client View is turned on in the instance. |
Salesforce-Specific Parameters
UserId
Optional | Your user ID. | string |
UserType
Optional | Your user type. For example, Standard, Admin, and Developer. | string |
AccountId
Optional | Your Salesforce ID. | string |
ProfileId
Optional | Your profile ID in your org. | string |
ContactId
Optional | Your contact ID. | string |
Lithium-Specific Parameters
boardsArr
Required | It limits search to the boards specified in boardsArr . |
string |
Example
getSearchResults
searchString = "help"
result = getSearchResults(
uid=uid, searchString=searchString)
print("The search result: ", result)
