Use D2L Brightspace as a Content Source
Brightspace by D2L is a cloud-based online learning platform. It provides a suite of software to develop tutorials, courses, and other learning collateral. To crawl and index your Brightspace instance data, add it as a content source. This article walks you through the process of adding D2L Brightspace as a content source.
Brightspace instance login credentials, preferably admin account credentials.
An OAuth 2.0 App for SearchUnify and its Client ID and Client Secret. More information: Obtaining D2L Brightspace Client ID and Client Secret.
Client URL. Enter https://auth.brightspace.com.
Language. Select the language of your Brightspace content.
Client ID. Enter the client ID for the app you have created. More information: Obtaining D2L Brightspace Client ID and Client Secret
Client Secret. Enter the client secret for the app you created. More information: Obtaining D2L Brightspace Client ID and Client Secret
Base URL. Enter community.desire2learn.com.
You will be redirected to log into your Brightspace community. Use your credentials to log in. After the login is successful, click Next on the Connection Successful screen.
Now you can set a crawling frequency.
Select Content types for Indexing
Select the object and fields for indexing after establishing a connection and configuring frequency. Currently, only the Content object is supported.
Under the Rules tab, go to the the By Content Type subtab. You can see the content object listed here. Click
to view the pre-configured content fields. You can edit or remove them according to your requirements.NOTE. It is, however, not advised to changes, if you aren't an admin.
When you switch to the By Categories subtab, use the alphabetical index to find spaces.
Use the checkbox to pick the selected categories for indexing. Once you have selected the categories, click Save.
You can now proceed with the manual crawl.
In Choose a Date, click
