Use Khoros Aurora as a Content Source
Khoros Aurora offers a more streamlined and feature-rich approach to online community management and customer engagement with enhanced usability and updated design, when compared to Khoros Classic Community (Atlas).
If your organization’s online community is developed on Khoros’ Aurora platform, you can index its contents in SearchUnify as explained below.
Prerequisite
You must have the account user credentials for Khoros Aurora instance, preferably admin credentials or an account that has an access to the necessary permissions and data access that you want to crawl in SearchUnify.
Find Khoros Aurora and click Add.
Name: Enter a name for your Content Source.
Client Url: Enter the Khoros community instance URL.
Language: Select the language of your Khoros Aurora community.
Username: Enter the username of your Khoros Aurora user account.
Password: Enter the password of your Khoros Aurora user account.
Shared Secret Key: Refer to this doc to know how you can get the Shared Secret Key: Obtain Khoros Aurora Client ID, Client Secret, Shared Secret Key
Client Id: Refer to this doc to know how you can get the Client ID: Obtain Khoros Aurora Client ID, Client Secret, Shared Secret Key
Client Secret: Refer to this doc to know how you can get the Client Secret: Obtain Khoros Aurora Client ID, Client Secret, Shared Secret Key
HTAccess Username: Enter the HTAccess Username of your Khoros Aurora community instance.
HTAccess Password: Enter the HTAccess password of your Khoros Aurora community instance.
Fig: A snapshot of the Khoros Aurora Authentication tab.
If the entered details are correct and the connection is successfully established, you will be directed to the Frequency tab.
Select Objects and Content Fields for Indexing
Once you have set up the connection and frequency, next define the fields whose data you want to index in SearchUnify. All Khoros Aurora objects are supported in SearchUnify.
In the Rules tab, you will see the By Content Type subtab and you can see the list of the supported objects.
Fig: A snapshot of Khoros Aurora objects preconfigured in the Rules tab.
Click EDIT to see the pre-configured fields of an object.
NOTE. You can add or delete the content fields. Although, it is not recommended for users other than admins to make any changes in the fields.
Switch to By Boards subtab. Find your boards with the index. For example, a board named "Lithium Discussions" is found under "L" as shown in the image below.
Note(s):
If you have added or deleted a board, use Reindex to view the latest list of boards.
If no board is selected, then SearchUnify will index data from all the boards.
After selecting the fields whose data you want SearchUnify to index, click Save.
To index your Khoros Auora community contents, start the crawl.
Related Doc: (Re)crawl a Content Source
Click Save to apply settings
In Choose a Date, click
