Get GetGuru Username and Usertoken
The username and usertoken of your Guru instance is required to complete the authentication process in SearchUnify.
Obtaining Guru Username and Usertoken
Log into your Guru instance. From the main page, click Team Settings.
Under Team Settings options, click Users and Collections.
You will see a list of all users under All Members tab. The highlighted part is your username.
Now, click Apps and Integrations.
Navigate to API Access.
Click Generate user token and select a user for whom the token is to be generated.
After selecting the user, click Generate Token.
Copy the token and use it in SearchUnify for authentication.
