SearchUnifyGPT™
SearchUnifyGPT™
SearchUnifyGPT™ is a generative AI widget that enhances the search experience by delivering highly relevant and informative results.
Key features:
Works with Salesforce Console, Khoros, Salesforce Communities, Zendesk, and all website search clients.
Includes hyperlinks to the sources used for generating answers, ensuring transparency.
Fig. A snapshot of a SearchUnifyGPT™-generated answer.
Steps to Enable:
Connect SearchUnify to a Large Language Model (LLM) such as OpenAI. The instructions to connect SearchUnify with a third-party LLM are on Configure LLM Integrations.
Toggle SearchUnifyGPT™ to ON in the Configurations tab.
Select an LLM from the dropdown.
Configure Query Length Limit using the slider:
Minimum query length: 1 word(default).
Maximum query length: 6 words (default).
Adjust these values as needed for your instance.
Example:
If the minimum value is 5 and maximum value is 12, then SearchUnifyGPT™ will be triggered only when a search query is 5 words or longer but 12 words or shorter.
For example, a query like[set up Salesforce content source] will display an answer in the SearchUnifyGPT™ widget but a query like[set up Salesforce] won’t return an answer.
Stopwords are not ignored. It means that for SearchUnifyGPT™, a query like [salesforce is a content source] consists of 5 words.
Here's an example of SearchUnifyGPT™ on a Search Client:
Fig. SearchUnifyGPT™ on a search client.
Differences from Rich Snippets:
SearchUnifyGPT™ synthesizes information from multiple sources. Rich Snippets extract content from a single source.
Rich Snippets support multimedia; SearchUnifyGPT™ currently supports text-only answers.
