Use Thought Industries as a Content Source
This article outlines how to crawl and index your data hosted on a Thought Industries platform.
PERMISSIONS
The archived data is removed from the index in every frequency crawl.
- Find Thought Industries and click Add.
- Under the Authentication tab, enter the required details:
- Give your content source a Name.
- Enter the web address of your Thought Industries instance in Client URL.
- Select the language content. It is possible to select more than one languages.
- Enter your Thought Industries API Key in Authentication Method and click Connect. You can find the API Key at Settings > Security in the Passwords & Keys section in Thought Industries.
Thought Industries has only one object, content_items
. SearchUnify can index it and all the fields inside content_items
to select content fields.
- Use the dropdown in the Name column to add content fields one at a time. Once you have added all the fields, click Apply.
- OPTIONAL. SearchUnify assigns each field a label, type, and either an
isSearchable
orisFilterable
tag. The values don't require a change, but advanced users can edit them. - Press Save.
You have successfully added Thought Industries as a content source in SearchUnify. Perform a manual crawl to start indexing the Thought Industries data in SearchUnify.
Click Save to apply settings
In Choose a Date, click
