Install a Search Client in Zendesk Guide
Improve self-service with a smart search engine for Zendesk Guide. This article walks you through the process of installing a SearchUnify search client on a Zendesk knowledge base.
- Ensure the Help Center is activated in Zendesk Guide
- Set up and configure Zendesk Guide
- Download the Zendesk Guide search client and unzip it
Installation
- Log into Zendesk.
- Using
, move to the Zendesk Guide dashboard.
and then View Theme.
- Launch Edit Code.
- Copy the scripts from
index.html
. Unzip the downloaded search client (see Prerequisities) to findindex.html
. - Insert the copied scripts into
header.hbs
. - Replace the code in
search_results.hbs
with the code inindex.html
. - Navigate to
home_page.hbs
and find the div with the classhero-inner
. - Replace the div
hero-inner
with the code copied fromautocomplete.html
. (You can findautocomplete.html
in the downloaded search client.) - Press Publish.
