AI Escalation Manager Analytics - Open Escalation Prediction Cases
Use this report to monitor which open cases are at risk of escalation, how long escalations have been active, and where to focus effort.
Note: Values shown in screenshots are illustrative. Your environment displays live data.
Filters
Date Range and Agent (single or multi-select).
Use Apply to refresh reports data and Clear All to reset.
KPI Cards
Open Cases
Total open cases in the crm. (based on filters).
Open Escalations
Open cases that are currently escalated per your rules.
Avg. age of Escalated Cases
Average time (days) since creation for cases that are escalated right now.
Example: 2.5d.
Avg. age of Escalation Duration
Average time (days) that the current escalations have been escalated (from the moment each case entered escalation to now).
Example: 2.8d.
Admin tip: If Open Escalations is flat but Avg. age of Escalation Duration rises, escalations are lingering—review staffing, SLAs, or blockers.
Escalation Predicted Cases Bar
A color-coded bar shows how open cases are distributed by Escalation Score (0–100):
Green = Non-Escalated (0–34)
Amber/Yellow = Medium-Escalated (35–59)
Red = Escalated (60–100)
Use the download icon near the chart to export the view.
Escalation Predicted Cases Table
A paginated list of in-scope open cases. Columns:
Case ID SU — SearchUnify internal case identifier (if available).
Case ID SF — Salesforce case number/ID.
Customer Name — Contact/requester (may show N/A if not synced).
Account Name — Customer account (may show N/A for community/consumer users).
Agent Assigned — Current owner/assignee.
Case Ageing (in Days) — Days since case creation.
Case Created Date SU — Creation timestamp indexed by SearchUnify.
Case Created Date SF — Source-of-truth creation timestamp from Salesforce.
Escalation Score Initial — Risk score when the case was created/ or the conversation started if using L1 agent case entered the open queue.
Escalation Score Current — Latest risk score based on recent signals.
Note: You’ll see N/A in two scenarios:
The field doesn’t exist in the source,
You don’t have permission to view it.
How to Use This Report
For Support Managers/Agents
Triage by risk: Sort by Escalation Score Current to address highest-risk cases first.
Check age vs. risk: Prioritize cases that are red and older than your SLA targets.
Stabilize escalations: For already-escalated cases, add clear updates, confirm next steps, and set expectations to drive the score down. Also, the timely alerts are shared on the given email address.
For Admins / Team Leads
Read the four KPIs together:
Open Cases and Open Escalations indicate volume.
Avg. age of Escalated Cases and Avg. age of Escalation Duration indicate timeliness.
Coach via deltas: Compare Initial vs Current scores. If many cases trend upward, revisit triage, coverage, or staffing.
Drill by agent: Use the Agent filter to spot outliers (high current scores + high ageing).
Export for reviews: Download the bar or table for weekly ops reviews and action plans.
Permissions
You’ll only see records and fields allowed by your Salesforce permissions.
Analytics respects tenant visibility rules and index scope.
