Field Mapping Between Khoros and SearchUnify
This article visualizes the mapping between the fields found on the Khoros frontend and the SearchUnify fields under the tab Khoros Content Source > Edit > Rules. Using this document you can pick the right fields for crawling and indexing in SearchUnify.
Here's an example: The highlighted area in the image is called "current_revision" in Khoros but its name in SearchUnify is "last_update_time".
To index the data stored in "current_revision" pick the "last_update_time" field while choosing Khoros fields for indexing.
| Search Field Name | Fields from API Response & Description | Visual Representation at Khoros Front-End |
| subject | subject (It provides the information of message title) | |
| kudos | kudos (It gives the information of message kudos) | |
| body | body | |
| parentCategoryName | parentCategoryName (It provides information about the board that it belongs to which Parent category ) | |
| data_category_nested | dataCategoryNested (store the nested data of category) | |
| data_category_flat | dataCategoryFlat (store the array of strings of category title) | |
| products | products (stores the array of strings of product title) | |
| parentCategoryId | parentCategoryId (store the array of strings as a board id’s) | |
| rootCategoryName | root_category (It provides information about the board that belongs to which root category) | |
| rootCategoryId | root_category (It provides information about the board that belongs to which root category) | |
| boardName | board (It provides information on the board name) | |
| boardId | board (Provides the ID of the board) | |
| author | author (It provides information that who created the message ) | |
| authorHref | author (It provides information that the author details) | |
| type | conversation (Provide the information on type of board i.e. forum, Events)) | |
| view_href | view_href (It provides the URL of the message) | |
| replyCount | replies (Provides the count of replies in each message) | |
| solved | conversation | |
| viewCount | metrics (Provides the count of views in each message) | |
| label | labels (Provide the labels in each message) | |
| comments | replies (It provides information on comments in each message) | |
| tags | tags (It provides information on tags in each message) | |
| metadata | Images Videos |
| id | id | |
| file | attachments (It provides the information on the file uploaded in each message) | |
| replies | replies | Comments Count |
| moderation_status | moderation_status | |
| grouphub_id | groupHubId (It provides information on the group hub in each message) | |
| boardNameTitle | board (It provides information on the board name title in each message) | |
| grouphub_short_title | grouphubShortTitle (It provides information on the Group Hub short title ) | |
| grouphub_description | groupHubDesc (It provides information on the Group Hub description ) | |
| grouphub_view_href | groupHubHref (It provides information on the Group hub link ) | |
| grouphub_membership_type | ghbMembershipType (It provides information on the Group hub membership type. This group hub is closed, open ) | |
| grouphub_title | ghbTitle (It provides information on the Group hub title. ) | |
| last_update_time | current_revision (It provides the date when the message is edited.) |
