Field Mapping Between Litmos and SearchUnify
This article visualizes the mapping between the fields found on the Litmos frontend and the SearchUnify fields under the tab Litmos Content Source > Edit > Rules. Using this document you can pick the right fields for crawling and indexing in SearchUnify.
Here's an example: The highlighted area in the image is called "OriginalID" in Litmos but its name in SearchUnify is "originalid".
To index the data stored in "OriginalID" pick the "originalid" field while choosing Litmos fields for indexing.
| Search Field Name | Fields from API Response | Visual Representation at Litmos Frontend |
| name | Name (This field represents the name of the course) | |
| name_formula | Name (This field might indicates formula or rule used to generate the name of the course) | Same as 'Name' |
| active | Active (This field indicates whether the course is currently active or inactive) | |
| description | Description (This field provides a textual description or explanation of the course) | |
| courseCodeForBulkImport | CourseCodeForBulkImport (Identifier used specifically for bulk import operations related to courses) | |
| originalid | OriginalID (It represents an original identifier or unique key associated with the course) | |
| view_href_type | view_href_type (It indicate the type or format of the hyperlink used for viewing the course) | |
| view_href | view_href (This field contains the hyperlink or URL used to view the course.) |
For Learning Paths Object
| name | Name (This field represents the name of the learning path) | |
| courses | Courses (This field contains the list of all the courses in the learning path) | |
| description | Description (This field provides a description of the learning path) | |
| ecommerceShortDescription | EcommerceShortDescription (This field provides a brief description of learning path visible in the e-commerce or public catalog ) | |
| ecommerceLongDescription | EcommerceLongDescription (This field represents an original identifier or unique key associated with the course) | |
| price | Price (The price of the learning path if it is available for purchase) | |
| accessTillDate | AccessTillDate (The date until which access to a learning path is granted) | |
| accessTillDays | AccessTillDays (The number of days for which access to a learning path is granted) | |
| learningPathTeamLibrary | LearningPathTeamLibrary (This indicates if a learning path is part of a team library) | |
| forsale | ForSale (This indicates if a learning path is available for purchase) | |
| originalid | OriginalId (The original identifier for a learning path or associated course) | |
| isEquivalency | IsEquivalency (This indicates if a learning path/course is considered an equivalency) | |
| seqId | SeqId (A sequential identifier for ordering or categorization ) | |
| learningPathImageURL | LearningPathImageURL (The URL for the image associated with the learning path) | |
| post_time | post_time (The date and time when the learning path was created) | |
