SearchUnify MCP Tools and Response Formats
SearchUnify MCP exposes core tools for search, filtering, analytics, and search client discovery. The login tool is available only through the /mcp-connect endpoint.
Tool Purpose
search
Runs a SearchUnify query and retrieves relevant results
login
Starts the tool-based login flow through /mcp-connect
get-filter-options
Retrieves available filters or facets for a query
analytics
Retrieves SearchUnify analytics reports
get-search-clients
Lists available SearchUnify search clients
Note: The login tool is available only through the /mcp-connect endpoint. It is not available on standard OAuth or header-based endpoints.
Use the search tool to run a SearchUnify query and retrieve relevant search results from the connected SearchUnify instance. The tool can return standard search results or enriched GPT context, depending on the configuration of the SearchUnify search client.
Supported parameters
Parameter Type Required Description
searchString string Yes
Query text to search for. Minimum 3 characters and maximum 100 characters. Can be a single word, phrase, or sentence.
pageSize integer No
Number of results per page. Minimum 1 and maximum 100. Default is 10.
page integer No
Page number for pagination. Minimum 1 and maximum 100. Default is 1.
sortBy string No
Field used to sort results. Allowed values are _score and post_time.
aggregations aggregations No
List of facet filters used to narrow results. Use values returned by get-filter-options.
versionResults boolean No
Determines whether versioned document results are used. Default is false.
Aggregation Object Schema
Use the following schema when passing filters to the aggregations parameter:
Copy
JSON
  "type": "_type",
  "filter": "document"
Field
Type
Description
type
string
Aggregation or facet key, such as _index, _type, or documentation_category.
filter string
Selected filter value.
Example Request
Copy
 "searchString": "configure search client",
 "page": 1,
 "pageSize": 10,
 "sortBy": "_score",
 "versionResults": false,
 "aggregations": [
     "type": "_type",
Behavior notes
  • If the connected SearchUnify search client has GPT enabled, the tool returns enriched GPT context with links and descriptions.
  • If GPT is not enabled, the tool returns standard search hits with fields such as title, summary, and URL.
  • HTML tags are stripped from results automatically.
  • If versionResults is supported in the response, the primary document appears instead of separate versioned documents.
Sample Response
Copy
 "content": [
     "type": "text",
     "text": "title: How to Configure Search Clients\nsummary: Learn how to set up and manage search clients in SearchUnify.\nurl: https://docs.searchunify.com/search-clients\n---\ntitle: Content Sources Overview\nsummary: A guide to adding and managing content sources.\nurl: https://docs.searchunify.com/content-sources\n---"
login
Use the login tool to start the tool-based SearchUnify MCP login flow.
This tool is used when an MCP-compatible AI client connects through the /mcp-connect endpoint. It is useful in environments where the browser does not open automatically or where the client needs to display a login link directly in the chat.
Availability
The login tool is available only on the /mcp-connect endpoint.
It is not available on:
  • Standard OAuth endpoints
  • Header-based authentication endpoints
Supported Parameters
The login tool does not require any parameters.
Behavior
When invoked, the tool returns a connection link. The user opens the link, enters the required SearchUnify connection details, and completes login in the browser.
After successful login, the remaining SearchUnify MCP tools become available for the session.
Sample Response
Copy
 "content": [
     "type": "text",
     "text": "Please present this login link to the user so they can connect their SearchUnify instance:\n\n[Connect SearchUnify](https://mcp.searchunify.com/mcp-connect/login?s=<session_id>)\n\nIf your client supports clickable links, render the markdown above. Otherwise show the plain URL so the user can copy it. After the user completes login in their browser, let them know you are ready to continue."
User Login Fields
The user is asked to provide the following details on the SearchUnify MCP connection page:
Field
Description
Instance URL
SearchUnify instance URL
Search Client UID
UID of the search client that MCP should use
OAuth Client ID
Client ID generated from the SearchUnify API Client
OAuth Client Secret
Client Secret generated from the SearchUnify API Client
Important: For hosted SearchUnify MCP, the OAuth Client should use the MCP callback URL:
https://mcp.searchunify.com/su-callback
Recommended Use
Use login when:
  • The client connects to /mcp-connect.
  • The browser-based OAuth flow does not open automatically.
  • The AI client needs to display a login link inside the conversation.
  • The user needs to manually complete SearchUnify MCP login.
The /mcp-connect is specifically intended for tool-based login and returns a clickable connection link in the chat.
get-filter-options
Use the get-filter-options tool to retrieve available filters or facets for a search query. This tool is useful when the user wants to narrow a search by source, content type, category, product, index, or another configured facet.
Parameter
searchString   Yes
aggregations   No
Existing filters used to retrieve contextual filter options for an already filtered query. Uses the same aggregation schema as the search tool.
Example Request
Copy
 "searchString": "case deflection",
 "aggregations": [
     "type": "_index",
     "filter": "Documentation"
Response structure
The tool returns an array of aggregation groups.
Each aggregation group can include the following fields:
Field Description
key
Internal key for the aggregation, such as _index or documentation_category.
label
Display label for the aggregation.
order
Sort order of the aggregation.
values
Array of available filter values.
Each item in values can include:
Field
Description
displayName
Display name of the filter value.
value
Internal value used when applying the filter.
contentName
Associated content source or content label, when available.
Sample Response
Copy
 "content": [
     "type": "text",
     "text": "[{\"key\":\"_index\",\"label\":\"Content Source\",\"order\":1,\"values\":[{\"displayName\":\"Documentation\",\"value\":\"Documentation\",\"contentName\":\"Docs\"},{\"displayName\":\"Community\",\"value\":\"Community\",\"contentName\":\"Community\"}]},{\"key\":\"_type\",\"label\":\"Content Type\",\"order\":2,\"values\":[{\"displayName\":\"Document\",\"value\":\"document\",\"contentName\":\"Document\"}]}]"
Recommended Usage Pattern
A common search refinement flow is:
  • Call get-filter-options with the user’s query.
  • Review the available filters.
  • Ask the user which filters to apply, if needed.
  • Pass the selected filters into the search tool through aggregations.
Example:
User: Search for SSO setup articles and show me the available filters.
Assistant: Calls get-filter-options.
Assistant: Presents available filters.
User: Limit it to documentation.
Assistant: Calls search with the selected aggregation.
It is recommended to use get-filter-options before search when an assistant needs to discover available filters and then pass selected filters into the search request.
analytics
Use the analytics tool to retrieve SearchUnify analytics reports.
This tool is intended for reporting workflows, search quality analysis, and content optimization use cases.
Parameter
reportType string Yes
Type of analytics report to retrieve.
startDate string Yes
Start date of the reporting period in YYYY-MM-DD format.
endDate string Yes
End date of the reporting period in YYYY-MM-DD format.
count number Yes
Number of records to fetch. Minimum 1, maximum 500.
sessionID string No Optional session cookie/session ID filter for sessionDetails and sessionListTable.
pageNumber number No Page number for search classification reports. Minimum 1, maximum 10.
startIndex number No Pagination page for sessionDetails and sessionListTable. Minimum 1, maximum 10. Maps to the API startIndex.
sortByField string No Field used to sort analytics results. Supported values: count, click, search, case, page_view, support, end_date, start_date.
sortType string No Sort direction. Supported values: asc, desc.
With SearchUnify MCP integrated with your LLM client, you can access insights from all supported SearchUnify Analytics reports available in the admin panel.
Note: For `sessionDetails` and `sessionListTable`, if `sortByField` is set to `count`, SearchUnify MCP sends it as `click` to the underlying analytics API.
Example Request
Copy
 "reportType": "searchQueryWithoutResults",
 "startDate": "2026-04-01",
 "endDate": "2026-04-30",
 "count": 20
Sample Response
Copy
 "content": [
     "type": "text",
     "text": "query: reset password\ncount: 42\n---\nquery: configure saml\ncount: 31\n---\nquery: search client uid\ncount: 18\n---"
Recommended Use Cases
Use analytics to:
  • Identify zero-result queries.
  • Find searches that returned results but received no clicks.
  • Review popular search queries.
  • Analyze search conversions.
  • Review average click position.
  • Investigate session-level activity.
get-search-clients
Use the get-search-clients tool to list the search clients configured in the connected SearchUnify instance.
This tool is useful when the user or administrator does not know which Search Client UID to use while configuring SearchUnify MCP.
The get-search-clients tool does not require any parameters.
Behavior
The tenant is derived from the authentication credentials used to connect SearchUnify MCP.
The tool returns minimal information about available search clients, including the search client name and UID.
Response Structure
Each search client can include the following fields:
Field
Description
id
Search client ID.
name
Search client name.
uid
Search client unique identifier.
search_client_type
Type of search client, such as Web App or Salesforce. Available on supported SearchUnify admin versions.
Sample Response
Copy
 "content": [
     "type": "text",
     "text": "[{\"id\":\"101\",\"name\":\"Documentation Search\",\"uid\":\"8f8b0c7e-0000-0000-0000-000000000000\",\"search_client_type\":\"Web App\"},{\"id\":\"102\",\"name\":\"Support Portal Search\",\"uid\":\"7d7a0b6d-0000-0000-0000-000000000000\",\"search_client_type\":\"Salesforce\"}]"
Recommended Use
Use get-search-clients when:
  • The user does not know the Search Client UID.
  • An administrator needs to identify which search client to connect to MCP.
  • A developer wants to verify that the authentication credentials can access the expected SearchUnify instance.
  • The tool lists search clients configured in the connected SearchUnify instance. Each returned search client can include fields such as id, name, uid, and search_client_type.
Standard MCP Response Format
SearchUnify MCP tools return responses using the standard MCP content structure.
A typical response contains a content array. Each item in the array has a type and a text value.
Standard Response Example
Copy
 "content": [
     "type": "text",
     "text": "title: How to Configure Search Clients\nsummary: Learn how to set up and manage search clients in SearchUnify.\nurl: https://docs.searchunify.com/search-clients\n---"
Response Behavior
Successful tool responses use the standard MCP content array. The returned text can vary based on the SearchUnify search client configuration and the tool invoked.
Tool Selection Guide
Use the following guide to decide which tool to invoke:
User Intent
Recommended Tool
Search enterprise content
search
Discover filters before searching
get-filter-options
Apply selected filters to a search
search with aggregations
Start login through /mcp-connect
login
Find Search Client UID
get-search-clients
Retrieve zero-result queries
analytics with searchQueryWithoutResults
Retrieve no-click queries
analytics with searchQueryWithNoClicks
Retrieve all search queries
analytics with getAllSearchQuery
Retrieve conversion data
analytics with getAllSearchConversion
Example Workflows
Search with Filters
User asks: Find documentation about SSO and show only documentation results.
  1. Call get-filter-options with searchString = "SSO".
  2. Identify the relevant documentation filter.
  3. Call search with searchString = "SSO" and the selected aggregation.
  4. Return the filtered search results.
Tool-Based Login
User asks: Connect my SearchUnify instance.
  1. MCP client connects to the /mcp-connect endpoint.
  2. Call login.
  3. Show the returned connection link to the user.
  4. User completes login in the browser.
  5. Continue using search, get-filter-options, analytics, or get-search-clients.
Find a Search Client UID
User asks: Which Search Client UID should I use?
  1. Call get-search-clients.
  2. Review the available search clients.
  3. Select the correct UID based on the client name and type.
Search Analytics Review
User asks: Show me the top zero-result queries from April.
  1. Call analytics.
  2. Set reportType = searchQueryWithoutResults.
  3. Set startDate and endDate.
  4. Set count.
  5. Return the analytics results.
