Obtain an Access Token from a Refresh Token
In a previous article, you learned to generate both refresh and access tokens. This article documents the call to be used to obtain access tokens at regular, short intervals.
curl --location --request POST '{{hostname}}/oauth/token' \
--header 'authorization: Basic base64encode({{clientid:clientsecret}})' \
--header 'cache-control: no-cache' \
--header 'content-type: application/x-www-form-urlencoded' \
--data-urlencode 'grant_type=refresh_token' \
--data-urlencode 'refresh_token={{refresh token}}'
Hostname
In {{hostname}}, enter your SearchUnify instance URL.
Headers
The call requires three headers.
| Header | Value | Type |
authorization
Client ID and client secret encoded in base 64. Details on: Get Client ID and Client Secret with an API Client | String |
cache-control
Always no-cache |
String |
content-type
Always |
String |
Parameters
There are two parameters in the call.
| Parameter | Value | Type |
grant_type
Always refresh_token |
String |
refresh_token
The refresh token obtained from the first curl call. Details on: Get Access and Refresh Token Using curl | String |
Content Type Error
There will be a 404 error.
"statusCode": 400,
"status": 400,
"code": 400,
"message": "Invalid request: content must be application/x-www-form-urlencoded",
"name": "invalid_request" }
