Use Higher Logic Vanilla as a Content Source
Higher Logic Vanilla (formerly Vanilla Forums) is a popular cloud-based online community platform. If your online community is hosted on Higher Logic Vanilla, SearchUnify provides a connector for using it as a content source.
Permissions
While adding Higher Logic Vanilla in SearchUnify, make sure you have admin privileges in Higher Logic. Only admins can generate a Personal Access Token, which is required for authentication in SearchUnify.
Role-based permissions are respected in Higher Logic Vanilla. It means that users can see the content that has been assigned to their roles. For the Groups object, content searchability works on Public, Private, and Secret-based permissions.
Permissions on indexed data are updated every 15 minutes.
- Navigate to Content Sources and click Add New Content Sources.
Find Higher Logic Vanilla and click Add.
Enter the following details for authentication:
Client URL. Enter the URL of your community instance.
Language. Select the community language.
Username. Enter either your email address or your community username.
Personal Access Token. Enter the personal access token of your Higher Logic Vanilla community.
Refer to the following doc for instructions on how to generate a personal access token: Generate an Access Token in Higher Logic Vanilla
Click Connect after you have entered all the required details,
For this content source, the Choose a Date feature is grayed out. That's because during each crawl all the data is indexed from scratch. You can select the crawl frequency after configuring the content source. For now, click Set.
Select Content Types and Fields for Indexing
Currently, two space types–Category and Knowledge Base–are supported out of the box. Each object has several fields, which you can add and remove the existing fields that come pre-configured.
Under the Rules tab, By Content Type is the selected subtab.
You can see the discussions, articles, events, and groups are already added. Click on the edit button from the Actions column to view and edit the pre-configured fields.
NOTE. It is not recommended for users other than Admins to make any changes in the fields.
Switch to By Categories subtab. Use the alphabetical index to find Categories and Knowledge Base. Those alphabets are highlighted in blue which have a category under it.
For example, Community (Knowledge Base) is shown under alphabet C.
Use the checkbox to select the categories for indexing. Click Save once done.
You have successfully added Higher Logic Vanilla as a content source in SearchUnify. Perform a manual crawl to start indexing data in SearchUnify.
Click Save to apply settings
(View Crawl Logs) in Actions.
For this content source, the Choose a Date feature is grayed out. That's because during each crawl all the data is indexed from scratch. You can select the crawl frequency after configuring the content source. The following options are available for the Frequency field:
Click Set to save the crawl frequency settings.
The frequency crawl currently runs as manual crawl for Higher Logic Vanillla as the whole data is re-crawled from scratch.
The Frequency should be set to 30 minutes or higher to avoid frequency crawl failures.
Higher Logic Vanilla Webhook
Webhooks help SearchUnify receive update APIs from Higher Logic Vanilla and thus, updating the crawled data. This helps end users find the latest content and not the archived content. Also, the webhook helps update Group-level permissions.
The steps to creating a webhook in Higher Logic Vanilla are mentioned in this doc: Add Webhook in Higher Logic Vanilla.
For Delivery URL, contact your CSM. It's a unique URL that will be provided by the SearchUnify tea. And select all Events from Which events should trigger this webhook? section.
