Use MS Teams as a Content Source
Microsoft (MS) Teams is a great collaboration tool for organizations invested heavily in Microsoft 365. It's used for internal communication, such as inter-team messaging and chatting. SearchUnify can index the data stored in public channels on Microsoft Dynamics.
Connecting MS Teams with SearchUnify helps end-users search through posts, files, wiki, and tasks. SearchUnify respects access control settings so that users can search the content based on the teams and channels they are part of and the permissions assigned to them.
Establishing A Connection
  1. Navigate to Content Sources.
  2. Click Add New Content Source.
  3. Locate Microsoft Teams from the list of supported content sources. Once located, click on the Add button next to it.
  4. Enter a value in the Name field and click Connect.
  5. A pop-up screen will appear. Click Allow to allow SearchUnify to access MS Teams' data.
  6. Click Next to complete the connection.
  • To reauthenticate
  • To fix a crawl error
  • To change frequency
Select Content Type for Indexing
There are several content types in the MS Teams. And further there are several fields for the respective content types like Team, Team Owner, Channel Name, Channel Owner, Channel Description, Messages, Posts, Replies, etc. You can choose to index all of these properties, or some of them. It is, however, recommended to index all properties.
  1. Click to select message properties for indexing.
  2. Use or to edit or remove properties and click Save.
  3. Navigate to By Channel.
  4. Use the index to find your channels, check the box in Enable column to index them, and click Save.
Upon clicking Save, your MS Teams' content types will be indexed immediately based on your crawl frequency settings or it may take some time based on the amount of data that is to be crawled.
  4. Click Save.
