Search API
Get search results data in JSON.
Before making your first API call, ensure that you have completed the following prerequisites.
1. Set a user scope
SearchUnify users can have one of five user scopes, each affecting the API calls they can make. Follow the instructions in Change User Scope (API and SDK) to modify a user’s scope.
2. Create an app
Client ID and Client Secret are created at the time of app creation. These credentials authenticate your identity. Learn how to create an app and obtain these credentials in Get Client ID and Client Secret with an API Client.
3. Obtain access and refresh tokens using the app
To use this API, you need access and refresh tokens. Follow the steps in Get Access and Refresh Token Using curl to generate them.
Using Access and Refresh Tokens
The token generation process provides two types of tokens:
Refresh Token – Valid for 14 days. Store it securely, as it is only used to generate new access tokens.
Access Token – Expires every four hours. This token is required for user authentication and must be included in the header of all API calls.
After generating refresh and access tokens, use the following format for using the Access Token in API calls.
Base URL
The Base URL for all API calls is:
https://{{hostname}}/api/v2_search/
Where hostname is the URL of your SearchUnify instance.
Example Base URL
https://mycompany.searchunify.com/api/v2_search/
Endpoints
View search results on a platform of your choice.
Parameters
| Parameter | Optional / Required | Description | Data Type |
uid
Required | It is your search client ID. You can find it in Search Clients > UID (column). | string |
searchString
Required | It is the search query. | string |
email
Optional | This parameter is used establish the searcher's identity and tailor search results based on that identity. An admin email might fetch results different from a moderator email. | string |
orderBy
Optional | It has two values, asc and desc. If orderby=desc, then the order in which the results are presented is reversed. The last result will be ranked first, the penultimate result second, and so on. The default value of orderBy is asc. |
string |
sortby
Optional | It can have two values, _score or post_time. When sortby=_score, then the documents with the highest score are presented first. When sortby=post_time, then the lastest documents are on top. |
string |
exactPhrase
Optional | It treats all the words in the search query as one contiguous string. exactPhrase=salesforce console becomes "salesforce console". |
string |
withOneOrMore
Optional | When used, it inserts the Boolean operator OR between each pair of keywords. withOneOrMore=salesforce console becomes "salesforce OR console". |
string |
withoutTheWords
Optional | This parameter inserts the Boolean operator NOT before each keyword. withoutTheWords=salesforce console becomes "NOT salesforce NOT console" |
string |
from
Optional | It's an offset. If from="10", then the call will ignore the top 10 results and fetch results starting from the document ranked 11. |
string |
resultsPerPage
Optional | If resultsPerPage=30, then each search will produce 30 results on each page. |
string |
indexEnabled
Optional | The content sources tabs are hidden if indexEnabled is set to false. In the default state, indexEnabled=true. |
boolean |
aggregations
Optional | aggregations is used to refine your search with facets. For example: type: ${facet name}, filter: [ ${facet filter name1}, ${facet filter name2} ]. A common pattern for nested facets is [{type: ${facet name},children: [ childname: ${facet child name1}, level: ${facet level} ]}] |
object |
pagingAggregation
Optional | It is used if your goal is to display all your facets. {key: ${facet name},keyword: ${facet search keyword},offset: ${number of filters to shown}} |
object |
pageNo
Optional | Returns search results from the specified page number. If pageNo==5, then the results from the fifth page will be returned. |
sid
Optional | Attaches session ID(s) to the returned data. | |
language
Optional | Returns results in the specified language. language=zh returns Chinese results. |
versionResults
Optional | Merge multiple versions of a doc into a result. | |
getAutoTunedResult
Optional | Returns auto tuned results. Works only if Auto Spell Corrector and Facet Interpretor are enabled in the instance. | |
getSimilarSearches
Optional | Returns results from the similar searches tab. Works only if Similar Searches is turned on in the instance. | |
mergeSources
Optional | Groups results by content sources. Works only if Customize Search Client View is turned on in the instance. |
Salesforce-Specific Parameters
UserId
Optional | Your user ID. | string |
UserType
Optional | Your user type. For example, Standard, Admin, and Developer. | string |
AccountId
Optional | Your Salesforce ID. | string |
ProfileID
Optional | Your profile ID in your org. | string |
ContactId
Optional | Your contact ID. | string |
Lithium-Specific Parameters
boardsArr
Required | It limits search to the boards specified in boardsArr. |
string |
Example Request
curl -X POST 'https://grazitti.searchunify.com/dev/api/v2_search/searchResults'
-H 'Content-Type: application/json' -H "authorization: Bearer ACCESS_TOKEN"
--data-binary $'
\n"uid":"SEARCH_CLIENT_ID",
\n"searchString":"salesforce",
\n"sortby":"_post_time",
\n"resultsPerPage":"20" \n
