Stage 1 Case Deflection from Search and SearchUnifyGPT™
Stage 1 Case Deflection from Search and SearchUnifyGPT™ is the sum of case deflection by the answers generated by SearchUnifyGPT™ and Case Deflection Stage 1. It occurs in two scenarios:
  • SearchUnifyGPT™ generates an answer for a query, the search user reads it, and doesn't visit the support page. It is called Successful SUGPT sessions sans Search.
  • The search user clicks on a search client and doesn't visit the support page. It's called Successful Search sessions sans SUGPT. It is the same as Stage 1 Case Deflection.
View Stage 1 Case Deflection from Search and SearchUnifyGPT™
  1. Navigate to AnalyticsSearch AnalyticsConversionsSearch Analytics Overview.
  2. From Apply Filters, select one of the following:
    • Unsuccessful Search Sessions
    • Successful Search Sessions (sans SearchUnifyGPT™)
    • Unsuccessful SearchUnifyGPT™ Sessions:
    • Successful SearchUnifyGPT™ Sessions (sans Search)
  3. To view the numbers, click Case Deflection.
Stage 1 Case Deflection from Search and SearchUnifyGPT™ Terminology
The following terms are used in the Stage 1 Case Deflection from Search and SearchUnifyGPT™ report.
  • C / CS: Successful Search Sessions without Support Visit
  • H: Total Search Sessions
  • N: Sessions with Direct Page View followed by exit without performing Search or visiting Support
  • IDV: Implicit Deflection Volume
  • DPV: Direct Page View
  • IDR: Implicit Deflection Rate
  • CG: Successful SearchUnifyGPT Sessions without Support Visit
  • CSG: Successful SearchUnifyGPT & Search Sessions without Support Visit
  • IDVS: Implicit Deflection Volume by Search
  • IDVG: Implicit Deflection Volume by SearchUnifyGPT
  • IDVSG: Implicit Deflection Volume by Search & SearchUnifyGPT
Each term is defined next.
The C / CS in Stage 1 Case Deflection from Search and SearchUnifyGPT™ is the total number of user sessions where a user performs a search, finds the needed information, and resolves their issue without subsequently visiting a support page or creating a support ticket.
The H in Stage 1 Case Deflection from Search and SearchUnifyGPT™ is the total number of times users initiate a search.
The N in Stage 1 Case Deflection from Search and SearchUnifyGPT™ is the count of user sessions where a user directly lands on a content page, finds the answer to their query on that page, and then exits the site without performing a search or navigating to a support contact page.
The Implicit Deflection Volume (IDV) is total number of sessions where users successfully resolve their issues through self-service without contacting support. The IDV captures deflections from various channels.
The Direct Page View (DPV) is the total number of instances where a user accesses a content page directly, rather than navigating to it via a search result or other internal links.
The Implicit Deflection Rate (IDR) is the ratio of Implicit Deflection Volume to Total Search Sessions or Relevant Total Interactions. The IDR displays the effectiveness of self-service in deflecting support cases.
The CG in Stage 1 Case Deflection from Search and SearchUnifyGPT™ is the count of user sessions where a user successfully resolves their issue through interaction with the SearchUnifyGPT™ AI assistant, without subsequently visiting a support page or creating a support ticket.
The CSG is the count of user sessions where a user utilizes traditional search and the SearchUnifyGPT™ AI assistant to successfully resolve their issue, without subsequently visiting a support page or creating a support ticket.
The IDVS is the Implicit Deflection Volume attributed to user resolutions achieved through traditional search functionality.
The IDVG is the Implicit Deflection Volume attributed to user resolutions achieved through interactions with the SearchUnifyGPT AI assistant.
The IDVSG is the Implicit Deflection Volume is attributed to user resolutions achieved by leveraging both traditional search and the SearchUnifyGPT AI assistant.
