Use Higher Logic Thrive as a Content Source
This article explains how to establish a connection between SearchUnify and your Higher Logic Thrive community. Through the connection, SearchUnify can index the data of your Higher Logic Thrive-powered community and make it searchable.
PREREQUISITES.
A non-empty Higher Logic Thrive community
Admin credentials to Higher Logic Thrive Community
- Find "Higher Logic Thrive" and click Add.
Enter the following details for authenticating your Higher Logic Thrive community:
Client URL. Enter the URL of your Higher Logic Thrive community instance..
Language. Select the primary language(s) of your community using the drop-down.
Username. Enter the username/email used for logging into Higher Logic Thrive community.
Password. Enter the password used for logging into Higher Logic Thrive community.
HLIAM Key. Enter the IAM key. The process to obtain the key has been described in Get Higher Logic Thrive IAM Key.
For this content source, the Choose a Date feature is grayed out. That's because during each crawl all the data is indexed from scratch. You can select the crawl frequency after configuring the content source. For now, click Set.
Select Fields for Indexing
You can index the data of the supported five Higher Logic Thrive content types; Discussion, Event, Library, Blog, and Announcement. Under the Rules tab, you will see the list of supported objects in By Content Type subtab.
Click the Edit button to see the list of pre-configured fields for that object. A dialog will open where you can add, edit, or remove content fields.
Note. It is although not recommended to make any amends in the pre-configured fields.
Switch to By Communities subtab, and you will see all the communities and you can check the communities, whose data should be indexed.
After selecting communities, click Save.
Click Save to apply settings
(View Crawl Logs) in Actions.
For this content source, the Choose a Date feature is grayed out. That's because during each crawl all the data is indexed from scratch. You can select the crawl frequency after configuring the content source. The following options are available for the Frequency field:
Click Set to save the crawl frequency settings.
Data Deletion and SU Index
A method to update the index in real time is to enable event subscriptions, which supplement existing crawls and synchronize data between your Higher Logic Thrive instance and SearchUnify in real time. The instructions are on Synchronize SearchUnify Index with Higher Logic Thrive through Event Subscription
