Use Stack Overflow for Teams as a Content Source
Stack Overflow for Teams is a secure, private Q&A platform that helps organizations share knowledge, improve collaboration, and reduce reliance on individual experts. It centralizes institutional knowledge so that it’s easily discoverable and accessible to team members.
To make your Stack Overflow for Teams content searchable through SearchUnify, add it as a Content Source. This document outlines the steps.
The following are required for authentication:
Personal Access Token (PAT)
Team Slug
In Content Sources, locate Stack Overflow for Teams and click Add.
Enter the required connection details:
Name: A label for this source, e.g., Stack Overflow for Teams.
Language: Select the language for your content. (Default: English (en).)
Personal Access Token (PAT): Enter your token for authentication.
Team Slug: Enter the team slug for authentication.
Click Connect.
If the credentials are valid, you’ll be taken to the Frequency tab.
Select Object and Fields for Indexing
Once the connection is established and crawl frequency is configured, specify which Stack Overflow for Teams content to index in SearchUnify.
Go to the Rules tab → By Content Type subtab. You will see the Stack_teams_question object.
Click
to view the object’s preconfigured fields. Select the fields you want to index.Reference list (preconfigures fields for Stack_teams_question): id, title, tags, comments, answers, owner, comment_count, is_answered, view_count, answer_count, score, last_activity_date, post_time, tag, description, view_href.
Note: You can add or remove content fields, but only admins are recommended to make these changes.
After selecting the fields to index, click Apply.
Switch to the By Tags subtab.
Search for and select the tags whose linked content you want to include in the SearchUnify index.
After selecting the required tags. click Save to apply the settings.
Initiate the crawl to begin indexing your Stack Overflow for Teams content.
Related doc: (Re)crawl a Content Source
Click Save to apply settings
(View Crawl Logs) in Actions.
In Choose a Date, click
