Configure LLM Integrations
The LLM Integrations feature enables you to connect SearchUnify with a Large Language Model (LLM), such as OpenAI, enhancing the search experience with AI-powered responses.
Before you connect SearchUnify to an LLM, you must have:
An active LLM account
A website Search Client or a Salesforce Communities Search Client
Configuration
In the Admin Panel, navigate to LLMs and expand Integrations.
The LLM Integrations screen has two sections:
SearchUnify Partner Provisioned LLM
Bring Your Own LLM
Fig. A snapshot of the LLM Integrations screen.
Partner-provided LLMs offer better data security than the third-party LLMs listed in Bring Your Own LLM and include a trial period. The current options include:
AWS Bedrock: Now available with a 14-day trial. To obtain the authentication details to connect SearchUnify with AWS Bedrock, please contact your IT or DevOps team or the person responsible for administering LLMs within your organization. When the free trial expires, contact the SearchUnify team to continue using AWS Bedrock.
Fig. The SearchUnify Partner Provisioned LLM section on the LLM Integrations tab.
Bring Your Own LLM
This section supports third-party LLM integrations. The supported LLMs include:
OpenAI
OpenAI Service
Gemini
AWS Bedrock
Anthropic
Connecting OpenAI
To activate OpenAI, enter the API key. Then click Connect.
Fig. A snapshot of OpenAI activation.
Connecting OpenAI Service
To activate OpenAI Service, enter:
The Base URL for Azure OpenAI API access.
The Unique API Key for authentication.
The name of your Azure OpenAI deployment.
API version of Azure OpenAI.
Then click Connect.
Fig. A snapshot of OpenAI Service activation.
Connecting Gemini
To activate Gemini, enter the API key and click Connect.
Fig. A snapshot of Gemini activation.
Connecting AWS Bedrock
To activate AWS Bedrock, select an authentication type:
Basic Authentication
AK/SK Authentication
If you have selected Basic Authentication, enter
Region; where region is the place where your Bedrock service is hosted
API Key; the AWS Bedrock API key for authentication
Access Key Secret; the AWS Bedrock API access key for secure authentication
Then click Connect.
After successfully establishing a connection, you can switch the authentication type. However, switching the authentication type will remove all saved details. Before switching, disable the AWS Bedrock integration and the SearchUnifyGPT toggle in Search Clients > Configurations. After switching, enter the required details again to activate AWS Bedrock.
Connecting Anthropic
To activate Anthropic, enter the API key and click Connect.
Fig. A snapshot of Anthropic activation.
Then click Connect.
Activate, Deactivate, and Clear Details
To Activate a connection, move the Connection toggle to the right. To Deactivate a connection, move the same toggle to the left.
Fig. A snapshot of an activated connection.
Click Cancel to clear the API Key. Once the API Key is cleared, features that depend on the LLM will stop working. The two impacted features are SearchUnifyGPT and Summarize Results. After entering the new key, activate LLM for those features again.
Fig. A snapshot of an Cancel button.
LLM Usage Insights
LLM token usage can be viewed in LLM Usage Insights.
Activating SearchUnifyGPT™
Once you are connected to the LLM, you must activate the SearchUnifyGPT™ to enable the LLM-powered answer box.
Navigate to Search Clients > Edit > Configurations.
Toggle SearchUnifyGPT™ to ON in the Configurations tab.
Select an LLM platform and a model from the dropdown.
Please select the LLM Integration*: Select an LLM platform.
Please select the LLM Model*: Select an LLM model.
Note: If selected model isn't in your subscription, you will see a warning.
Scroll down to enable Additional Configurations. In this section, you’ll find the Query Length Limit configuration, which allows admins to define when SearchUnifyGPT™ should be triggered.
For example, if the slider is configured so that the Minimum query length is 5 words and the Maximum query length is 12 words, then SearchUnifyGPT™ will run only for search queries that are at least 5 words long but not longer than 12 words.
In such a scenario:
A query like [set up Salesforce content source] (5 words) will trigger a response in the SearchUnifyGPT™ widget.
A query like [set up Salesforce] (3 words) will not trigger SearchUnifyGPT™.
Note: Stopwords are not ignored. For example, the query [salesforce is a content source] is counted as a 5-word query.
The default values are:
- Minimum query length: 1 word
Maximum query length: 6 words
After defining the Minimum query length and Maximum query length, click Enable to activate the configuration.
Note: Two analytics reports are activated when you toggle on SearchUnifyGPT™ on a search client. The reports are:
Using the SearchUnifyGPT™ Answer Box
Note: SearchUnifyGPT™ works for Salesforce Console, Khoros, Salesforce Communities, Zendesk, and all website search clients.
Once you have connected to an LLM and activated SearchUnifyGPT™, the LLM-powered answer box will appear above the search results. The text in the box updates when you apply facets. The SearchUnifyGPT™ widget will not appear in two scenarios: 1) Page two and beyond, and 2) On empty searches. Users can view the full response by clicking Show More.
Fig. A snapshot of the Show More button on SearchUnifyGPT™.
The sources used to generate the answer are listed in the widget. The users can hover the cursor over a source number to view details.
Fig. A snapshot of the link details dialog, when the cursor is over a reference.
The users can share feedback on the accuracy of the data in the widget using the thumbs-up-and-thumbs-down feature. The feedback is captured in the SearchUnifyGPT™ Feedback Report.
Long answers in the widget can be copied using the Copy button.
Fig. A snapshot of the copy text, thumbs up answer, and thumbs down answer buttons on SearchUnifyGPT™.
Known Issues
As a search user, you may encounter one of these issues:
NewLine characters: The SearchUnifyGPT widget may display new line characters in the search results.
Code printing: The widget may print code instead of generating natural language text.
Case file and case form (SF) incompatibility: The widget does not work with case files or case forms on Salesforce Communities.
