Use NICE CXone as a Content Source
NICE CXone (formerly MindTouch) is a popular knowledge management platform. This article walks you through the process of connecting your NICE CXone instance with SearchUnify.
PERMISSIONS
Permissions run on the basis of the your email.
Public permissions are respected. Pages with public permissions are visible to all.
Semi-public permissions are considered public. Pages with semi-public permissions are visible to all.
Private permissions are respected. Pages with private permissions are visible to assigned email addresses and the groups associated with the page.
Semi-private permissions are considered private. Pages with semi-private permissions are visible to assigned email addresses and the groups associated with the page.
Site-Level Permissions are ignored by SearchUnify. They are managed from inside your NICE CXone instance.
All user types, except Community Member, can be crawled in NICE CXone.
You can override all permissions at the level of search results with Bypass Permissions.
Find NICE CXone, and click Add.
Enter authentication details.
Name. A label for the content source. Stick to ASCII characters.
Client URL. The web address of your NICE CXone instance. If you aren't sure of the base URL, see your NICE CXone pro admin.
Authentication Type. No Authentication and Basic Authentication have been deprecated. Select API.
Language. Select the content language. It's possible to select more than one language. The default choice is English.
Client Username. The ID used to log into NICE CXone.
Client Secret and Client API. Check out Obtain NICE CXone Client Key and Client Secret.
Note. Only an admin or a pro admin can generate the API token and if they change the token, the token will be expired and the connection with SearchUnify will also be affected.
Suppose you have users named author, admin, and proAdmin. These names also represent the type of user. If an author creates a connection with SearchUnify, s/he will add the client key and secret of a particular domain with its username. So, Searchunify will only crawl the data of the respective user.
For this content source, the Choose a Date feature is grayed out. That's because during each crawl all the data is indexed from scratch. You can select the crawl frequency after configuring the content source. For now, click Set.
Select Fields for Indexing
SearchUnify supports only page_mindtouch object in NICE CXone. The attachment types crawled in SearchUnify are - PDF, DOCX, TXT, DOC, PPT, PPTX, CSV, XLS, and POTX.
Under the Rules tab, you will land on the By Content Type subtab.
You can see the supported NICE CXone object here. Click EDIT to see the pre-configured fields.
At last, Save your settings.
You have successfully added NICE CXone as a content source in SearchUnify. Perform a manual crawl to start indexing data in SearchUnify.
Click Save to apply settings
(View Crawl Logs) in Actions.
For this content source, the Choose a Date feature is grayed out. That's because during each crawl all the data is indexed from scratch. You can select the crawl frequency after configuring the content source. The following options are available for the Frequency field:
Click Set to save the crawl frequency settings.
Data Deletion and SU Index
Deleted page IDs are fetched through APIs between frequency crawls and removed from the SearchUnify index.
