SearchUnify APIs
SearchUnify APIs belong to the category of RESTful APIs. They are powerful, easy to use, and secure. Four APIs are available and documented on Swagger:
  • Analytics API
  • Content API
  • Search API
  • SearchUnifyGPT
To run the APIs on Swagger, use https://{{yourinstanceurl}}.searchunify.com/api-docs/, where {{yourinstanceurl}} is the first part of your SearchUnify instance.
Fig. A snapshot of the SearchUnify API documentation on Swagger.
First Time Users
All SearchUnify customers can consume the APIs after creating an app and obtaining access and refresh tokens. The app verifies your instance and the refresh token enables you to generate access tokens and use them in calls to the SearchUnify server. If this is your first time using the APIs, check out the following articles first:
API Limits
Learn about the limits on APIs to plan calls in a secure and reliable way. The details are on SearchUnify API Limits.
Besides APIs, the Developer Guides section documents how you can Secure a Web Search Client with Middleware.
