SearchUnifyGPT™
SearchUnifyGPT™
SearchUnifyGPT™ is a generative AI widget that enhances the search experience by delivering highly relevant and informative results.
Key features
Works with Salesforce Console, Khoros, Salesforce Communities, Zendesk Console, Zendesk Guide, Zendesk Support, and all website search clients.
Includes hyperlinks to the sources used for generating answers, ensuring transparency.
Fig. A snapshot of a SearchUnifyGPT™-generated answer.
Steps to Enable
If you haven't done it, then first connect SearchUnify to a Large Language Model (LLM) such as OpenAI and then follow the following steps. The instructions to connect SearchUnify with a third-party LLM are in Configure LLM Integrations.
Navigate to Search Clients > Edit > Configurations.
Toggle SearchUnifyGPT™ to ON in the Configurations tab.
Select an LLM platform and a model from the dropdown.
Please select the LLM Integration*: Select an LLM platform.
Please select the LLM Model*: Select an LLM model.
Note: If selected model isn't in your subscription, you will see a warning.
Scroll down to enable Additional Configurations. In this section, you’ll find the Query Length Limit configuration, which allows admins to define when SearchUnifyGPT™ should be triggered.
For example, if the slider is configured so that the Minimum query length is 5 words and the Maximum query length is 12 words, then SearchUnifyGPT™ will run only for search queries that are at least 5 words long but not longer than 12 words.
In such a scenario:
A query like [set up Salesforce content source] (5 words) will trigger a response in the SearchUnifyGPT™ widget.
A query like [set up Salesforce] (3 words) will not trigger SearchUnifyGPT™.
Note: Stopwords are not ignored. For example, the query [salesforce is a content source] is counted as a 5-word query.
The default values are:
- Minimum query length: 1 word
Maximum query length: 6 words
After defining the Minimum query length and Maximum query length, click Enable to activate the configuration.
Note: Two analytics reports are activated when you toggle on SearchUnifyGPT™ on a search client. The reports are:
Here's an example of SearchUnifyGPT™ on a Search Client:
Fig. SearchUnifyGPT™ on a search client.
Differences from Rich Snippets
SearchUnifyGPT™ synthesizes information from multiple sources. Rich Snippets extract content from a single source.
Rich Snippets support multimedia; SearchUnifyGPT™ currently supports text-only answers.
