Configure Analytics Properties
Analytics Properties is the second tab in Analytics Settings. It offers advanced configurations to configure how analytics data is gathered. The configurations are available in two sections:
  • Top section contains the following configurations:
  • Down section contains the following configurations:
    • Support Page Url allows you to define the URL where users can create a case or contact support. After entering the support page URL, turn on Show Stage 2 Deflection (Support Page) to start capturing analytics.
    • Capture Direct Pageviews in Session Journey allows you to define the URL the URL for Direct Pageviews, where Direct Pageviews refers to those visits to web pages when the users land on it through means other than search.
    • Select any type of implicit deflection allows you to pick a formula for calculating Stage 1 Case Deflection. Two values are available:
      • Stage 1 Deflection (Old Formula)
      • True Deflection (New Formula) Recommended
    • Show GenAI (SearchUnifyGPT) Impact in Analytics
